vcSweptVolumeMethod
Parent: Enum
Referenced by: vcSweptVolume.Method
How to access:
import vcCore as vc vc.vcSweptVolumeMethod.<ENUM_VALUE> # replace <ENUM_VALUE> with the desired enum value
Enums
| Value | Description |
| HULL_FROM_HULLS | Uses hull from hulls generation. Creates internal faces and more points, thereby a higher data count but supports all types of movement. |
| HULL_FROM_HULLS_V2 | Updated implementation of HULL_FROM_HULLS. |
| HULL_FROM_SILHOUETTES | Uses hull from silhouettes method to generate geometry. Balance of methods 0 and 1 to support small and complex movements. |
| LOFTING | Uses lofting to generate swept geometry. Good for movements requiring small changes, for example small rotational and directional changes in linear motions and bending of curves. |
